Removing the monitor from Wild Western?
Mitsurugi-w
New Bern, North Carolina
I have this cabinet that used to be a Wild Western and needs the tube replaced but I'm not sure how to take this cab apart. Its kinda sticking together from the years so I just need to know how you remove the glass and the monitor before I break something. Thanks!
There should be some 2 x 1 1/2 timbers bolted to each side , under the metal monitor frame....remove the bolts that go through them(timber & cab sides, closest to the back) the monitor and frame will swing down for monitor removal.... as tester007 said...glass should slide out the back .
john
I'm pretty sure you can also remove the bolts that hold the metal frame to the wood frame and slide the monitor and frame out that way. Have to be careful with the wiring though it's pretty tight in there and the monitor frame tends to catch the wires running up one of the sides.
