Removing NT 500DX chassis
adams_arcade
Donor 2012, 2023
What kind of tool do I need to remove the phillips screws at the back of the tube. There is no way to get a screw driver in there to remove them...HELP!!!!!!
If you have a link to a tool so I have a visual I would appreciate it!
Need to get this chassis out asap!
Well, you could pull the tube.
But if you look underneath, I think you can remove the plate it mounts to, then remove the screws once you have the plate out...
