removing centipede cocktail control panel
hovo
quebec, Canada
hey guys, i dont know how to remove the cp from my centipede cocktail
theres is 2 bolts attached to the cabinet itself, and the cp consists of 2 parts,
both << I suppose glued to eachother>> with hinges
thanks for your help
anyone please? im trying to get this done during the holidays, and i really dont want to screw it up
Each of the bolts has a nut on the inside I believe that you have to access through the top. Then it just comes right off.
@major havoc-- the manual dosent cover this unfortunately
@fearsumfearful-- that i do know, but thing is even then its gonna be hard installing a cpo while the hinges are still on
has anyone tryed installing a cpo on a similiar game, or a game which its control panel hinges were glued?
thanks
If the CP is stuck, give it a little persuasion. After the bolts are out, it will come off.
You have to get the control panels off and cleaned up/painted before you can put the new CPO's on.
thanks, ill try that,
but the thing is that the cp has hindes on it,
I know how to remove the bolts but even then its going to be hard dealing with those 2 metal pieces,
its a bit hard to explain, whats I get the whole cp assembly out ill take some pics to give you guys a better understanding
