Removing a Sanyo 20EZ
kentmurphy
Missouri
What is the best way to remove a Sanyo 20EZ from a DK cab? Do you have to remove the bolts which hold the brackets to the side of the cab or can you unscrew the top and bottom braces? I'm confused.
Kent
You unbolt the base from the shelf it is sitting on, then remove the bolts holding it to the top bracket and lift it out.
Make sure to unplug it, and disconnect the speaker connector, sound board connector, and video input cable before taking it out...
I don't remember. Been a while since I pulled one. And that's assuming whomever did it last put them all back...
There are 2 screws holding the bottom of the monitor to a bracket on the shelf, and 2 screws holding the top part to the bar across the back.
As I recall, once you pull those screws, you have to slide it 1/4 in or so to one side to clear some clips, or maybe rotate it slightly?
There was some oddity, but it was fairly evident upon inspection.
