Remove Coin Door Off Hinges?
paulliadis
Bellefonte, Pennsylvania
The coin door on my DK Junior is beat pretty good. Could use straightening and repainting.
I see the bolts that I can use to remove the door. Some look easy to get to, some not so much. My question is this: has anybody removed the door without removing the door frame? Is there a way to take the door off the hinges? Has anybody done this?
Mine is the standard door found on Donkey Kong / Donkey Kong Jr.
Paul
Haven't worked on a Nintendo cab, but the common coin doors have 4 tiny screws that fasten the door/hinge to the frame. Look for those screws.
The hardware on the door and the mounting bolts are all metric. I use a long socket extension to get to the nuts at the bottom of the door frame.
