Remote switch for Happ Power Pro
brandogg
My Warzaid arcade cabinet uses a Happ Power Pro for the power supply, and the rocker switch is very inconveniently (only) located on the bottom/back of the cabinet. I know the power supply supports a remote switch, which can be wired to the 4-pin molex coming from the power supply, but I'm not sure how to wire it. I assume black is hot, white is neutral, and then that connects to blue and brown when the switch is closed, I'm just not sure if blue is hot or brown is hot (or if it really even matters). Anyone know? I was going to run up thr hardware store to buy a DPDT rocker switch, and I have the necessary molex connector on hand, and plenty of wire. Thanks!
Update: I'm an idiot, diagram is literally on the sticker on the power supply, lol. Black to brown, white to blue.
If you want excruciating detail:
Thanks, my situation ended up being super simple, just wired black/white to one side of the switch, blue/brown to the other. A little drilling and vacuuming later and now it's got a nice on/off rocker on top like it always should have.
