Rejuvenator Adaptors
Oryk Zinyo
Bremerton, Washington
I have a few home built adaptors for sale. These are designed to be used on the B&K model 467 and above. Model 466 rejuvenators will need to be modified to use these adaptors. I can do the modification or walk you through it.
CR23 - This is the most common "arcade" adaptor and is used on G07, 4600, 4900, and many of the K7000 series monitors.
CR30 - As far as I know this is only useful for Matsushitsa monitors.
CR31 - This is the adaptor used for small neck tubes. Many of the 13" monitors as well as K7000 19" tubes use this adaptor.
I am selling these adaptors for $25 a piece plus $5 for shipping. I can fit up to three adaptors in one box.
hey how much do the Rejuvenator's sell for? i know a local tv repair man that wants to sell me his for $250-$300... it comes in a nice carrying box and has like 10 diffrent adaptors included along with a couple manuls.. is that a good price? what are they worth?
thanks guys!
It depends on what model he has. If his is a B&K unit like these adaptors fit it is only worth $30 to $150 depending on which model and what adaptors are included. There are other manufacturers who built more expensive models and they are worth more. Comparing the model he has with completed auctions on eBay is a good starting point...
Pm sent for a CR23, also wondering what adapter fits vector monitors like asteroids, tempest, star trek, ect.:cool:
As far as I know the black and white vectors use the CR6 adaptor and the color vectors use the CR24, however I have limited experience with all of the vectors and the only one I am certain of is the K6100 (CR24). A CR23 can be used on the color vectors if you are willing to remove the plastic shroud off of the neck. This will allow the CR23 to slip on the neck but the red and green guns are reversed (the readings are swapped).
Any pictures? I'm curious to see how you handled the adaptor end.
I have a 467 and wouldn't recommend paying any more than $50 for it, with some of the adaptors included. Shop around, you'll find a deal.
Here is a pic of the adaptors. I chose to solder the wire directly to the legs of the neck socket. Then I covered the soldered area with shrink wrap. From left to right the adaptors are a CR23, a CR30, and a CR31. The socket on the bottom of the pic is an example of the new neck sockets I have available for making CR23's.
I am going to bump this up because some helpful KLOVers have helped me acquire the parts necessary to build a few CR31 adaptors. After contacting everyone on my waiting list I have a few left.
These are the same price as before $25 for each adaptor plus $5 shipping. Up to three can be packed into one box. I have CR23 and CR31 adaptor parts in stock.
It looks like all of the CR31 adaptors are spoken for; I still have the parts for CR23 adaptors, though.
Hopefully I will have a few more CR31 adaptors available within a week.
I have considered it but I don't have a Sencore machine to use as a reference. If you'll send me your Sencore machine as a reference tool I can build you a couple.
PM me if interested.
There is the problem. :) I don't know if my sencore works yet, since I need at least one adaptor that works on my monitors to test it. I have a possible connection for the ones I need, so let me see if that pans out first.
Thanks for the offer..
