action76
I have a K7000 with a R-A63ADG25X tube with a very weak red gun. I purchased a B&K 467 to try and fix it. The red gun was reading well into the red (bad) on the 467. The Blue and green were fine. I rejuvenated it about 3 times and got it into the yellow (barely). The last time I did it I had the G2 switch in the high position. The red is better than it was, but not good at all. Is there any tricks or tweaks you can do with the rejuvenator to get a better result of is this tube just beyond help?
Thanks,
Stephen
Thanks,
Stephen
