Rejuvenating B&W vector tubes
ieure
Donor 2014-2015
Portland, Oregon
Is this possible? I have a 15ST4730R I want to test, but it isn't listed in the BK setup chart.
There are no "B&W vector tubes".
There is just "tubes". I recently put a B/W TV tube in my LL. Worke like a charm.
Every tube can be rejuvenated unless it is totally dead.
B&W tubes all use the same socket. I just double checked this in the Muter rejuvenator list and that tube -is- listed there and indicating to the only B/W adapter that rejuvenator has.
So, find the B&W adapter for a BK rejuvenator and you're good to go.
Really? I thought vector monitors were different. I have been looking for a spare for my Asteroids if all I need is the right size B&W TV then I might be able to find one locally.
Do you have a link to a guide for the tube swap?
Why are original vector monitors so sought after then? And what about Space Duel color vectors?
I was talking about the TUBE not the entire monitor.... the tube is just a _part_ of a TV/monitor....
Yes a vector monitor is totally different from a raster monitor but the tubes they use are identical.
Here is the thread where I replace the burnt _tube_ of a B/W vector monitor with the _tube_ of a standard B/W TV....
http://www.dragonslairfans.com/smfor/index.php?topic=3209.msg53146#msg53146
