andrewb
Refurbished 2-way Defender/Stargate/Moon Patrol joystick w Zeroplay kit - $95 shipped
I have another refurbished Williams 2-way stick available, with ZeroPlay kit installed. This is the stick used for Defender, Stargate, Moon Patrol, and other games.
This stick has an original base and shaft, but has been completely cleaned and rebuilt with a Zeroplay bearing and axle kit, from jimmer (jbgaming.co.uk)
If you are unfamiliar with the Zeroplay kit, it's the ultimate upgrade for a Defender stick, and is used by most of the world-class Defender players. It replaces the original axle mechanism with a new machined stainless steel axle, sealed bearings, and shim washers, so you can eliminate all excess up/down and left-right play. See here for info:
http://www.jbgaming.co.uk/controls/zeroplay-bearing-kit/
Details:
- Original base and leaf switches.
- Original leaf centering springs and fishpaper inserts, all in good shape.
- Original shaft (in excellent condition, with no wear groove where it meets the base).
- Shaft has been drill sanded and polished.
- Ball has been polished, but has some light marks from normal use.
This stick has zero slop, tight springs, and is smooth as butter. If you've never tried one, you'll be impressed.
$95 shipped in the US. Int'l shipping extra.
Details:
