pinkpot
ok a guy bought a machine off me and asked if i could fix his laser ball machine.
1st off there is corrosion on almost all switches (cleaning them slowly but surely as thats quite grueling)
dead diodes on 4 switches (no biggie)
it scores for no reason (even after adjusting the switches) if u barely tap the machine it scores...looks like on the left side driver or just switches??? did it more when i got it i unhooked some switches so they stopped scoring
no drop target stickers so i put some on. the coils are to weak to lift them with stickers (wow!!!) was fine before that but i never checked the voltage...it seems low in comparison to other coils on the machine
(replace them or is that another problem???)
i have never seen corroded lamp posts looks like it was underwater ;(
cleaned them with 200 grit sand paper on the outside and used some cleaning lamp stick i bought.. (long process but again no biggie)
the driver was burnt in some spots from the ps being overdriven by high fuse values ;(
cleaned traces and reran caps and things...
any help on my few questions from ayone is appreciated.thanks
