Red tent trouble :(
drummerjosh1984
Missouri
Well it would seem that side 2 isn't working. When I had a board with excitebike on the other side (1) it showed a faint "shadow" of the game on the other side(2). So I plugged the board that was in there before back in and there is nothing on that side still. Side 1 never has had any green either, so I am unsure if they could be related. I was thinking of checking the voltage, but have never done so on a red tent. I looked in there and it seems different than a standard power supply, although I only spent a few minutes messing around. Since I couldn' t find a flashlight, and its getting late. Any help is appreciatied. If you could point me in the direction of the best way to check the voltage/where at/ I would like to start there. I have tried multiple boards and games.
Also my excitebike has no track, its just red.....
Do you have sets of chips in both the left and right sides of your board? You need to have 2 sets of excitebike ROMS if you want it to show up on both sides. One side of the board is for one side of the game.
And the "shadow" you are seeing is probably just screen burn (a burned image of the game that used to be played on there)
And the "no green" is going to most likely be a monitor problem.
Yeah I have seperate games on both sides. But the image on the other side was actually a moving image.... I swapped some of the cpu's around I think that may be the culperate.
