red tent to playchoice instruction sheet
delayed
Tennessee
Anyone have a clean scanned copy of this PC10 instruction sheet for the red tent?
I've seen 2 versions of this card. One like the above and on Riemens site, the other was in a NOS kit. The one above and on Riemens site doesn't make much sense color wise. The NOS one had the correct colors. I had OldTymeToys print me out one. The yellow could be a little oranger, but otherwise it was very nice. I think the Playchoice kit is a very nice addition to a Red Tent.
Yes,
The colors on this one were different from my buttons also. I messed around in Photoshop and changed things up a bit to match mine a bit closer. I don't really know what the correct colored buttons are since both of my red tents have different setups.
Here is a early compressed draft of my revision.
The reset combo does not work correctly on mine since I used a Vs harness. I don't see a wiring diagram within the conversion instructions you put up last year, so I guess I will have to wire it from the harness to a different button.
Yes,
The button colors should be blue-green-purple-yellow.
I thought you said the reset combo worked and that you were just having trouble when entering a name in the modified BIOS which requires the dedicated reset button?
Yes, just having troubles in that new bios menu.
"The button colors should be blue-green-purple-yellow."
is that 1-blue, 2-green, 3-purple, 4-yellow?
Here's a scan I just made of my Vs. Table NOS PC10 card. It could use a little touching up. You should post a cleaned up image when you can so others can use it.
Thanks for posting your scan. Hopefully others can clean it up.
