Red Donkey Kong Machine
thefader
South Dakota
Sorry about starting a new thread for this, the last one got kinda jumbled and I'll delete it.
Here is what I know so far
Serial Plate: Nintendo Co. LTD, Made in Japan. TKG2-US-UP Serial Number :10127
5 Bolts on Each Side
Coin Box Was Missing.
The transformer says 3D-0078 on it.
How do i tell what the power supply is.. No Markings?
On the Wood where the Power supply latches "4656" Was hand written.
Ill post more pictures tonite, anything else I should look for??
Is the iso black and does the power supply have 4 connectors or just 3?
From the number on the iso it should be the black one.
If there are 4 connectors then it is the PP-7A.
If there are 3 connectors then it is the PP-7B.
The later PP-7B also has the gold colored iso.
You should put this in the big thread.
Like jimkirk said, the original power supply should have a lable PP7A or PP7B (most likely PP7A in your case)
Original Transformer should be black (I think it's PT8A)
How many slots are on the front of the cabinet where the speaker goes? 5 or 7?
Also, on the 5 bolts holes, do any of them look like they were drilled after the fact (not at the factory?)
