Recycle rear projection TV's into Marquee/Backglass frames
The only problem is you need 2 of the same brand of TVs to get enough corners. You rip the projection screen bezel off the front. Then yank all the screens out of the grooves. Cut your extrusions to length and this is what you can do:
There are screws in the corner brackets to mount a hang wire and room for a small backlight because of the thickness of the TV bezels.
