Recently repaired 4600 has no red.
TheDrewster
Donor 2012
Reno, Nevada
I got my chassis back from Arcade Cup a couple weeks ago and when I installed it, I realized I had no red in the image and the green was waaay too bright. I tried a different tube and still got no red (one of which I accidentally necked afterwards...). Personally, I thought I just had two bunk tubes. Tonight, I rip a decent tube out of a junk cocktail I picked up yesterday and knowing full well it had all 3 colors. I swapped it in tonight and what do you know, still no red. Adjusting the red drive and red cutoffs make no change in the monitor. Needless to say I am very frustrated and this will likely be the last time I even dare working on these God-damn shitty-ass 4600 monitors (I had two fail right before I sold two games and I royally despise them and everything they stand for), but is there anything else I can try before sending it back for re-repair?
Dumb question, but are you sure it's the monitor and not the game PCB?
If you have another 4600, swap the input cards.
If not, you might change out the 2 transistors for red on that card.
Good thing is that at least those are cheap and available from the Shack!
I dont have any other compatible cards unfortunately. Which one is the Red transistor? And what type is it?
I would check the neck board transistor first. swap it with the green or blue one and see if the problem follows to that color.
TR204 -> MPS-A70
TR207 -> 2N3904
are the red transistors on the input card.
The 3904's are cheap and available at Radio shack or Bob sells them for a quarter each. Worth having a few in the parts bin for sure!
The A70's, not sure about shack availability.
Also, check to make sure red is making it from the input card to the neckboard!
