Recently received a Taito Double Dragon Arcade Cabinet, but can't find dip switches?
Shappy
Michigan
http://www.basementarcade.com/arcade/library/manuals/d/DDcase.pdf
It looks "kind of" like that, but not exactly. I would think that the DIP switches would be easily viewable when you open up the bottom drawer assemply? I also can't find the service button which is supposed to be right inside the door and to the right. :(
Welcome to the forum.
Here is a link to the game pcb manual http://www.crazykong.com/manuals/DoubleDragon.man.pdf
as said before the dips will be on the main pcb. and service switches are not always even wired into conversion machines. pin R on the edge connector (or the 14th pin on the solder side of the board) to dc ground will get you to service mode.
Ok, thanks guys. It's just as I feared... the dip switch board is missing. The game still turns on, but the coin slots aren't working properly and it also doesn't seem to have a service button. Back to the garage with it!
What do you mean the dip switch board is missing? The dip switches are on the main PCB, if it is missing then the game will never power up because it isn't there...
take some good pics of the inside of the machine, post them. We will point them out to you.
