Rebuilding a Game Plan MPU-1
Peale
Brattleboro, Vermont
I'm rebuilding a Game Plan MPU-1. It has the worst battery damage I've ever seen.
Despite the damage, I'm confident I can put it right again.
I soaked it in vinegar to neutralize the battery damage. Then I sandblasted it. Yes, it needed it.
So far the recovery has gone well. I've socketed everything (since I had to remove everything anyway, I socketed it all) and rebuilt the traces that got blown off.
The edge connector is a problem. My idea is to do something like Bob Roberts recommends for rebuilding an edge connector, except I'm having difficulty finding the connector itself to solder to it. I could probably go a bit longer, but not very much. Any idea where I could find one, preferably on Mouser?
Could you re-terminate the cable with a different connector, and then fly-wire it to the MPU Board? I know it would not be stock, and may be considered a Hack, but it would work.
From what it sounds like your rebuild sounds worse than the one that I did.
http://home.comcast.net/~dadindenver/live_to_fly_again.htm
There was one more trace that was open, and once that was repaired, the game worked great.
Good Luck, and post some pictures.
Mike
I *really* need to update that web page...
There was a switch matrix trace that ran under the Z-80 that was open. Fixed that and it worked fine.
Mike
Totally sweet. I can't wait to get to the part where I can actually plug it in.
For the time being, I'm not worried about the edge connector, as it only drives the display.
I am worried about my choice in cap replacement though. I'll post photos of what I picked up to replace the green caps.
Those should work fine. I just happened to have some better ones on hand that I used.
