Bullwinkle
I was recently working on a G07 with a bad fuse (the smaller one). I replaced the fuse and upon doing so, figured I'd recap it as well. After the cap kit, I powered it up and the flyback exploded... scared the hell outta me (nearly soiled my armor). Inspecting the flyback, there is a crack the entire circumference of the casing.
My question is this. I have another flyback and hot for a G07, is there anything that can cause the flyback to burst open like that other than a weakened casing / faulty flyback? (yes, I believe it was the original flyback).
I'll try replacing it if it's unlikely I'll have the same result from a new flyback/hot or is there another component failure that can cause this to happen?
Thanks,
Tom
Edit: I'm sure I'll need to inspect all surrounding components for damage
Thanks,
Tom
