Rear projection convergence help, pulling my hair out
Picked up a sega touring car championship super cheap, i have been messing with the convergence and have had no luck here is what it is doing... The center will line up perfectly I get blue bleed at the edges, and red well red is a beast all in its own, with words on the screen it is low on the top and high on the bottom making it impossible to converge. There is no brand on the 3 tubes as this is a deluxe cabinet, hell I cant even find where the rgbSG cable is to plug in a converter to attempt to see if it is a board problem or tube problem. Im lost as this sega model 2 b/c is unlike anything i have ever had or worked on. Any thoughts or ideas would be amazing. If a monitor fix is not feasable or economical any direction as far as using a gonbes 8220 converter would be much appreciated as well
