Real degaussing coils kick ass
Angry_Radish
Watertown, Wisconsin
I installed a new monitor in a Golden Tee last night and it came out of the box with a nasty spot at the bottom of the screen I couldn't get rid of with my little 8" degaussing coil to save my life.
I borrowed a 14"-ish professional coil from the op I do some work for and DAMN! Talk about a difference! I think it took maybe 8-10 seconds tops and I can't even tell where the spot was at all.
Next tool on my shopping list is a good coil, I can't live without this now :)
I'd like to be able to borrey one....I have a spot on one of my Golden Tee's.
make one.. i have a little 10 incher i think and that works for most.. you can make a stronger one yourself..
.. you can make one from a 25 inch tv or monitors degaussing coil.. take it off the tube, wrap it into a loop, tape well, then hookup the two coil wires, one direct to a wall plug termonal, the other one from the other plug terminal through a pushbutton switch then to the coil..
good way to make one yourself cheap. just dont leave it on too long, it gets hot quick..
This one feels and sounds like there is a heavy duty spring instead of just wire in there. Believe me when I say it was like night and day. I've tried the 25" tube coil with a momentary switch in the past, it just heated up too fast for my liking
I happen to have one from BITD and they suck for doing larger monitors. After about 8-9 attempts on my 27" monitor I bought a 12"-13" degaussing coil that fixed my issue in about 10 seconds.
I've used mine on a 29" monitor (needs to be done every time I move the machine) and never had a problem.
i bought Bob's 13" one a couple years ago, and its unbelievable. It literally has an effect at about 5' away from the monitor. Doesn't heat up either.
I just put it right in front of the monitor, hit the button, move it in circles and back away from the machine until the monitor quits waving, and its done.
