I have an Astron Belt cab with really cool original art, full wrap vinyl over particle board. However it has lost its adhesion and is peeling off from the edges badly. How can I re-adhere it to the particle board?
I thought about holding the loose parts up with one hand, painting contact cement with a brush inside, and when dry using my side art squeegee to push it back down and squeegee towards the edge. I'm just worried the cement will dry with chunks, and I'll see those as bumps through the vinyl.
Is there a spray adhesive that I could spray in between, that will lay flat and not show when I squeegee the art down again?
Thanks!
Thanks!
