223
I will do that!
Oh, ok, can you show a picture of the board? Just to see where it's connected to on the PC, sometimes if it's plugged into a second serial port, it won't detect it.The I/o board is serial, not usb
I meant on the PC, sometimes the PC will have 2 serial portsThere isn't a 2nd serial port. It can only be plugged in to 1 port on the motherboard.
oh okThe pc only has 1
This may sound stupid, but have you tried any of these methods?The pc only has 1
Brand new, so did this problem start with the old board? Because if so, than it's possible you may have to reinstall the software, if you have reinstalled the software, try again because it may have not installed the i/o functions correctly, contact raw thrills about your issue as well, they may be able to help youYes. I've tried all of those and this is a brand new board from betson
I see... ok then, hopefully the new PC worksI tried to reinstall the software again and it installed successfully, but still have the same "connect i/o board" error. Trying the new pc next, once the serial card delivers.
