FS Parts: Rare Nintendo Vs. Red Tent... PLAYCHOICE conversion Harness - complete
LyonsArcade
Rock Hill, South Carolina
Alright folks, here's one you don't see too often. Nintendo released a playchoice conversion kit for the Vs. Red Tent system, that would make 1 side of it play a playchoice system and the other side remained the Vs. system.
We came across one of the cabinets destroyed, missing the doors ,the box on the bottom, etc. but still had the original conversion harness in it.
Here's a few pictures, I looked in the manual and the only thing missing is the power supply assembly, and that harness.
There's a total of 3 harnesses, the main one that connected to the two edge connectors on the playchoice pcb... the small 4 pin transformer harness that came with the kit, and also the 9 pin power junction harness.
The LED pcb is there, as well as the bracket.
All this is untested, but should work fine, no guarantees. None of the wires are cut. Essentially it's the main harness, up to each molex connector.
There's also a video/sound harness for the monitor included.. and also the service switch assembly is included. Finally the harness for the two coin switches on that side is included.
$70 shipped in the continental U.S.
The cabinet now needs two power supplies, so you can power up two seperate game boards. One end connects to the power transformer block in the bottom of the cabinet, the other end is a 4 pin molex that plugs into the new power supply.
