ZRICE28
Picked up a Racin Force, and the guy said it played fine, but the picture went blurry and faded to black. He knew nothing about it, nor do I. There is a wire coming out of the neck board that is cut. Can't track down the other end yet. I let everything warm up, and flipped the power switch, and it started to spark at the chassis. Shut it down right away. Disconnected power to the monitor and flipped the switch, there was a faint buzz coming from the pcb, that would go away if I moved the wire harnes slightly. The monitor is a wg 25k7191. Voltage out of the isolation transformer is at 129. The whole thing looks complete and original, not all hacked up. Just looking for the right direction to go. Thanks.
