R98 on 447A
It's on a K7901 19". I'm with you, the spec shows a 2.2K 1watt, and the one I pulled off is a bit scorched but the color bands look to be Red, White, White, Green (or black).
I'm with you. I put a meter on it and I' getting 1.86, but that could be because of age/heat.
Strange.
You can't just put a meter on it and get an accurate result because it is parallel with a limiter. You will need to remove one leg from the circuit and then recheck it.
