phatchit
I recently picked up a Rocky and bullwinkle that had the power switched all fucked up and soldered together. The only way to power it on and off is to plug and unplug it. ANyway went and bought a new power switch cut the power wires free of a horrible solder job .Hook up the switch and bam power. The problem is when I flip the switch off I keep blowing a fuse. It seems that its power surging somewhere. What should I check or look at or look for . Please help .what did i do. If i leave the switch on and unplug it from the wall all is good but if i use the switch to turn it off . I pop a fuse. Its a 5a fuse thats located in the box thats above the switch . It has to fuse holders in it. Thanks .hope someone has an answer. PEace.
