I am tube swapping on a k7000 chassis but after checking some tube swap lists I am not so sure the yoke will work on the donor tube, so hopefully someone here will point me in the right direction. The reading on the original yoke is 1.5 ohms for horizontal and 10.3 ohms for vertical. The donor tubes readings are 1.3 horizontal and 3.3 vertical. Would this work or is it too much of a difference for the vertical?
