Quick question
Nephasth
Cheyenne, Wyoming
I've made all possible adjustments and this is the best I can get the picture. Cap kit?
What kind of monitor is it? Also, can you get rid of those retrace lines by turning down the SCREEN control, or are they always there?
-Ian
WG 19K7601. The SCREEN control did get rid of the lines...but the top 1/2" of the screen is skewed, sorry about not showing that in the pic.
I think there's a pot
I'm not sure if you have it on that chassis... but if you adjust the 50/60 pot, you might be able to work that skew out.
I had a different chassis that had a skew on one game, but no skew on another. It had to do with the way the game outputs were coming through.
Someone else on the forum had the same problem and he said that he adjusted it out with the 50/60 pot on the chassis and got it to an acceptable level. (he had a K7000)
Hope this helps.
This is in a dual monitor cab, the other monitor isn't experiencing the skewing. The manual makes reference to 50/60 as pot VR9, however, I can't locate VR9 anywhere in the manual's PCB layout drawings.
All that pot seems to do is bring the top few lines of pixels closer together or farther apart, didn't do anything for the skew.
The skew would be adjusted with the horizontal hold (2nd from left if pots are on the boards)....
