quick question about lethal enforcers
InjunSteve
GRANITE CITY, Illinois
i just picked up a lethal enforcers from KC on sat. pretty damn good condition, very happy with it. while its a fun game, just like all other cabs due to my limited space it raises the question: what other boards can be played in it? im talking just swap boards. i ask because i'm not familiar with gun games at all, looks to be very similar to any other jamma game, but i'm assuming that games like revolution x and T2 cannot be played in it due to the difference in gun. but could virtua cop, house of the dead or other type games be swapped out easily. thanks
Most of the newer gun games have hard drives so if you're only looking for a simple board swap the list is probably a brief one. LE 2 should work but maybe someone else will chime in with other games that will work as well.
-t
true though you could manually flip the picture as well...
Area 51 is plug and play with LE. I had both in my cab for a while but got bored with Area 51 so I sold the pcb.
I have a point blank now but the guns arent compatible. Bummer
really? i had always thought they weren't due to the LE mirror thingy...
i have an area51/max force in a dynamo cab...it's obviously not mirrored. could i put LE or LE2 in that cab and have it work? is it just plug/play or is there a setting i'd need to change on the LE board?
thanks.
you can put lethal enforces in an area 51 its just a dipswitch but you have to make sure if you put games into a LE cab it has the mirroe option to be plug and play
thanks for the quick replies guys. appreciate the help.
so just to clarify real quick, if i was to flip the monitor and flip the dip on LE to flip the screen, would that make it an easier to plug/play? rather than having to find one that has the mirror setting to change?
thanks.
Not sure about LE 2?
I think LE has the ability to switch its image via soft or hard dips (dont recall). Area 51 doesnt (again, if I recall) so I just switched screen orientation to flipped and then flipped the LE board dips to match. Worked perfectly.
Some people said the guns wouldnt work on area 51 but they were totally fine. I juiced the power to a touch over 5v and everything was good.
cool. thanks.
I swap le2 & police trainer in my LE1 cab.
