Quick NFL Blitz question
StreetzKing
Donor 2013
Hyde Park, New York
Hey guys, sorry for my stupidity. NFL Blitz on KLOV says Jamma+. Can this be put in a 2 player jamma cabinet? Is the plus just for players 3 and 4, or the hard drive? Is the pcb and hard drive all I would need in my jamma cab?
Yes you could put this is a 2 player JAMMA cab. The original blitz was only 2 players. If it is Blitz 99 or later you would need to change the dips to a 2 player panel. Also, the game will run in standard or med res. You can use 8-way joysticks if you want. The 49-way are way better but you would need to get a seperate wire harness for each joystick which connects them directly to the pcb. If you select 8-way in the dips the joysticks connect to the jamma harness like normal.
yea I would plan on 8 ways since I have a bunch of games in and out of this cabinet, So just plug and play after some dip changes? Thanks very much
