Quick Easy WG Star Wars Monitor Adjustment Question
Samuel-IGN
SAN FRANCISCO, California
I am not super proficient with monitors but I do adjustments all the time and I'm familiar with many layouts -- I just cannot figure out where the pots for color adjustment (if there are any?) are in the WG 19K6101 monitor in my Star Wars cab.
The extremely minor issue is that the yellow objects (towers, catwalks) are too green. I need to boost the yellow a bit -- or I guess take the green or blue down a notch. There are pots that say G BIAS, G DRIVE, R BIAS and R DRIVE on the chassis and that's about all I see. Before fiddling I wanted to see if anyone can give me a quick bit of advice.
Thanks!
I think I'll have a friend over who could use an accidental shock to adjust the various color GAIN pots, I assume those balance color? I think yellow is a combo of red and green, right? So maybe turn down the green or turn up the red? Man it's been a long time since those optics labs in physics...
What I've found with these pots is that they work weird. Normally you'd turn both pots UP (clockwise) to get bright colors. On the 6100, I've found you have to do the opposite - turn one down (counterclockwise) and one up (clockwise) to get bright colors. Turning them both the same direction gives you nothing.
Your method may vary...
