gozer5454 Volunteer: Google SketchUp Guru VAPS Joined Jan 2, 2009 Messages 6,833 Reaction score 307 Location Salem, Oregon Mar 5, 2010 #1 Capacitor C20. I can no longer see which way to put the neg/pos in. If following Bob Roberts cap map, does the longer (positive) leg go in the top or bottom hole? Thanks
KevinMullins Active member Joined May 27, 2009 Messages 2,187 Reaction score 10 Location Mcloud, Oklahoma Mar 5, 2010 #2 Positive lead connects with D12. Negative lead goes to ground. A quick continuity check of each hole and you should be able to tell which one is the negative hole.
OP OP gozer5454 Volunteer: Google SketchUp Guru VAPS Joined Jan 2, 2009 Messages 6,833 Reaction score 307 Location Salem, Oregon Mar 5, 2010 #3 Thanks my friend. I actually took a gamble and put it in the right way. Figured I had a 50/50 chance. LOL. ...I also play Russian Ruollette on the weekends.
