Quick button wiring question
hindered
Donor 2015
Kalamazoo, Michigan
If I wanted to trigger a button press from either of two buttons (i.e. the sword buttons on either side of the joystick on dragon's lair), can I daisy chain the buttons together (similar to wiring a ground) or do I need to run an individual wire to each button from the harness?
certainly you can run a wire from one button to the other and they both would
work if you had the proper wire coming to one of them from the harness.
