It's question time again for anyone who can help me out:
The base panel circled in yellow in the attached pic, I can see it sits inside of the side panel plywood. What I can't see is, is that piece sitting on TOP of the base/floor plywood? Or, is that piece the actual back wall that the floor plywood butts up against? I'm guessing it's sitting ON TOP of the base/floor plywood, but just wanted to get some confirmation.
Also, if anyone can get me the width of that board from the one side of the cab to the other, I'd appreciate it. I want to use the numbers that Phet gave me for the width of the door found above that piece, but I'm guessing the door is just slightly thinner in width, to allow for the hinge.
Thanks!
Thanks!
