Questions about Frogger ROMS - which MAME set to use?
87 t-66
North Carolina
I need to burn some Frogger roms. There are four roms on the main PCB that are labeled EPR-1015, EPR-1014, EPR-1013A, EPR-1012. It looks like these files are in froggers2.zip and not frogger.zip. Do I use all of the files from frogger2.zip or just those four? It is the 36 pin sega board.
for sega you want one of the froggersX versions
I think you want version 3 for the latest version. you should only need to replace the 3-4 roms next to each other (code ROMs) the sound and video should be the same for all the sega versions.
good luck!
-brian
good luck!
-brian
thanks for the info
