Question on RGB/CGA/EGA/YUV TO 2VGA VIDEO CONVERTER
arcaderookie
Tennessee
I have one of these. did not get instructions on this what so ever. was wondering if anybody could help me out on hooking this up the right way. If of all I would like to know if I can use a regular flat screen tv with this I know I can hook up a monitor to it. Would like a wiring diagram for a regular flat screen tv or monitor. the 2 blue serial output can I hook up 2 monitors to that if so where do I wire the RGB wires that come of the harness for them. I circle the RGB and wrote a note beside it to be answered too.
thanks in advance
basiclly I am wanting to either hook up a flat screen computer monitor or a flat screen lcd tv to the converter. I just need to know which output on the converter to use and what that goes with (flat screen tv or flat screen monitor). and the wiring diagram for each one from the harness to the converter. So I know I am wiring it up right. I can use this converter for either one right.
thanks
You need this type of plug on your harness (the one in the pics)
As far as wiring it's pretty straight forward : red / green / blue / black for video ground and white for the vertical sync.
If your the plug on your harness is different and you need a plug like the above let me know I can send you one for free if you're in the US.
I hooked mine up by crimping .156 female molex pins to my RGB wires and then putting some heat shrink tubing over the pin. What can I say, it's what I had available. :D
Yeah whatever works, I'll bring you a couple next time I come by, I've got like 10 of those sitting around.
