question for afterburner deluxe owners
fatherpain
Donor 2024
Fullerton, California
What is the motion sequence when afterburner deluxe powers up? does the seat roll side to side first, then the cab pitches forward and back....or is it the other way around? I'm trying to work through a motor warm up failure issue..I've replaced a bad pitch motor with a tested good one and am still getting the error...pitch limit switches are good. cab rollers are all lube spinning freely. Its been so long since its run correctly I cant remember what to expect when the game powers up. thanks in advance for the assist :)
Tom
Yeah the seat roll side to side first then then pitch motor kicks in. Have you checked for voltage at your pins? Very common for the pitch motor harness under the cab getting cut from moving with a fork lift.
