Question comparison LV2000 to LV6100?
Jimjaycee
Warren, Michigan
Is their a physical difference between the LV2000 and the LV6100 add on board.
For Wells Gardner K6100 monitors
picture.php
If there is...can you post a picture of the LV6100?
Thanks Jim
The LV6100 doesn't have/need pots to adjust the voltage.
Thanks Bungy and Level42 for getting involved with my post.. I work on quite a few Atari color Vectors and I really wanted to see the difference in the two products. At this point I think I'll stay with the LV2000 since I can adjust the voltage. On the other hand I like the fact that the LV6100 uses standard components instead of micro components in case of component failure. I have personally had one LV2000 fail, it was the version rev. 01 with standard transistors not Rev. 02 with micro transistors, it was a easy fix.
