arcaderookie
Has anybody bought these joysticks. If so, could I get your input on these. are they worth it. I like that you can switch from 4 to 8 way on top verses opening up the CP to get from underneath to switch. I just wasn't sure about the magnet and wanted to know how reliable these are and are they good joysticks. or is there other ones that are better that you can switch from top instead of bottom
Mag-Stik Plus Worlds only Magnetically Centered Joystick!
4-8 Way Switchable from top of the panel.
Our newest joystick. The Mag-Stik is not centered by a spring but using an internal magnet. A light action gives the ultimate in joystick feel and sensitivity.
Also switches from 4 to 8 way mode from the top of the panel!
This is the only joystick in the world which can be switched over from 4 to 8 way from the top with no lever or other unsightly intrusion. Keeps the panel arcade-real but still gives the ability to play all 4 or 8 way games with the true feel of the correct mechanically-limited stick.
To switch: Pull out the stick against the spring pressure, continue pulling while rotating, until the mechanism engages, then turn anticlockwise for 8-way, or clockwise for 4-way. The stick clicks into position when turned 45 degrees. The mechanism actually rotates an internal restrictor plate and also rotates the microswitch actuator for a perfect 4-8 way transition.
wanting to also know about the OMNI-Stik PRODIGY (TM) Arcade Joystick System too. How reliable is this. does this work better or worst then the mag stick plus. etc.
thanks in advance
thanks in advance
