Question about FUSES
Smart Bomb
Donor 2014, 2024
Kenner, Louisiana
what voltage fuse do I use if nothing is listed...for example i need some fuses for some games and in the manuals it only list it as "3amp SB".....or lists only "2 amp"
how do I tell if its 125 or 250 if the manual doesn't list it or it is not listed on the game boards or hardware?
for fuses, voltage is irrelevant, u can use a 120vac or 240vac fuse.
just dont use the automotive 12vdc or 32vdc ones.
so if i buy everything at 250 even if it calls for a 125 i will be ok?...I can increase the voltages, just not the amps, correct?
you will have 32v fuses on the atari SB in the 20a and 25a but thats the only ones i can think of that aren't 125/250v
