Those look amazing guys!!!
since it was brought up and Darrin and forwarded me an email as well addresing some of the alignment issues Ill post that info and hope shed some light on this.
First it sounds like brett used a different cab for these measurements so that could be problem 1
but like roadrunner said the coin door should cover this.
Brett Ill provide you with the proper measurements so you can correct this for future cabs.
So notes on the art/films themseleves. First Atari phsically cut the art out of the films for the final print color-The Dark Blue
which just leaves these areas white (vinyl exposed)
as opposed to just bleeding the art or color all the way in or out to the edge for example.
so the placement of this like Troy said is what it is and is not perfectly centered either
from side to side
I certainly be curious to know the fit on an orginal cab not to mention there couldve been a revision to the cab itslef or to the art at some point to correct any mis alignments during production which Atari has been known to do.
I would also asume that the thin black outline is the cab dimensions and measures
7/16" to the edge of the art on the left and 5/16" on the right so the art and coin door is offset at least 1/8" left to right and sets 1-15/16" down from the speaker cut out
and would love to see a pic of an orginal kickplate with the coin door removed to see if its offset any
