I spent 4.5 hours today and got pretty much everything I had left soldered. Later tonight I'll start installing the IC's into the sockets.
I still haven't ordered the DAC312's yet. I wanted to see if anyplace has them cheaper than Digikey. I also forgot to get a 40 pin socket for the AVG replacement board, and I'm one 14 pin socket short. Mouser was out of stock of the 100uf 35v caps when I initially ordered my parts but they have them again now, so I just placed my last order apart from the DAC's. Of course right after I placed the order I remembered that I don't have those nylon posts that hold the large transistors in place. Oh well, I'll come up with something.
A couple things of note on the BOM:
Item 107 - TP11 GND - This needs to be changed to a quantity of 2. There's one at the top of the board, and one at the bottom. I noticed it when I came up short 1, so right now I don't have anything in the reset holes. I've added one to my last parts order.
For some reason items 25 and 27 are the same part, 598-CD10ED390JO3F. They should be combined into one line item with a quantity of 3. Not a big deal, but it confused me for a minute or two since I'm using the BOM to check off items as I go.
Using the part numbers provided, the 3 capacitors at locations C4, C130 and C80 I received from Mouser are phisically very large. They look like they belong on a monitor chassis, not a game PCB. I'm guessing the values are OK, but they sure look out of place.
One other suggestion is to seperate the parts that you don't need if using DAC312's. I ended up ordering some before I realized that they were on the list, since I was just going down the list and pasting the part#'s into Mouser. When I noticed it I crossed off the items on the BOM that are crossed off in red on the PCB print out.
I've had a blast working on this project, and hope that it fires right up when I get a chance to test it. Maybe I shouldn't use the word 'fire' though! Many thanks to Tronic, Riptor and Bungy!
