Qnic 2500 Monitor V-position problem
hine62
Donor 2017
New York
Here is a pic of my problem:
https://drive.google.com/open?id=0B4mR82u61b_HdFZEM280RFpMQ2c
I did end up taking out the control board and cleaning it. The red connection needed to be re-soldered, because of a connection issue. Easy to do.
Unfortunately the vertical problem cannot be remedied by using the pots. I get a great image on the screen, but it is too high. While cleaning the board I found this:
https://drive.google.com/open?id=0B4mR82u61b_HY2hrZFlmbW5CMkk
I did download the manual, but this pot is not explained. Anyone have any ideas what it is used for? Could this be the fix for my problem? I don't think the yoke can be moved on the tube. Not sure...
Thanks in advance for any help.
if you want a kit with the best quality caps than we have the kits.
I didn't see my monitor listed on your site... qnic cgn2500.
I'd like to give a big thanks to security0001 for helping me with to cap my first chassis. I did have to change the vertical chip also. He was very helpful! Recapping and the vertical chip solved the V-position. Now on to the next problem... the horizontal coil.
hine62
