Bodie
I have a Qix cocktail I'm working on The battery board is clean with no visible acid damage and the battery has been removed. The rom board appears to have a rom chip backward, The screen basically has garbage so I reversed the chip back with no change on the monitor. I can press the service switch and get the message to open the coin door to begin test. I think I probably have a bad rom chip. --------------------------------------------------------------------------------
One last detail chip U3 is the chip that was backwards.
Does anyone have any advice, also if I bought a eprom burner to check the roms which one would work easiest with Qix?
Thanks in advance
Thanks in advance
