Qix Board(s) Questions
rainman154
Buffalo, Minnesota
Hey, so here is another lot that I picked up. I believe it is Qix as the box said so.
There are 6 boards inside that look great. I have no way of testing them.
How many boards does Qix have??? I am assuming I have 2 sets here.
Could this be the Qix II: Tournament? Both were released in 81.
How can you tell they are not Qix II? On KLOV it says both were released in 81.
I can't actually but it's possible one might be as one of your rom boards has one more rom than the other has. So possibly a missing rom, a different version like qix II or a different rom revision that doesn't need the extra rom. You can compare the labels on the roms on the two rom boards and see if one set is different. That may be a clue.
based on a little more research I would lean toward the one with the rom board that is missing one rom being qix
and the one that is not missing the rom being qix II
Anyone know value on these?
Depends if they work or not. Too bad I don't have my cabaret anymore or I'd test them for you. It always happend when you dump a game that needs working pcbs and they show up afterward. Anyway working you'd get $250 . If they're non-working 40-50 bones on them, maybe more depending on the location of the buyer.
Cool. Yeah, I was told around $100 NW for each. Anyone else local in the Twin Cities have a machine I could test these on?
I will update with some more pics of the corrosion around the battery.
