Fudd
bought a qbert wire harness off another klover and some of the pins at the mainboard aren't in the correct location. so i'm moving them into the correct spot.
my problem is LOWERCASE letters e,b,d on the lower right hand part of the wiring schematic. where would these be on the edge connector? there are 30 spots. the 1st side is numbered 1-30. i'm assuming the back side starts with CAPITAL A thru Z, does it start with lowercase a after that? if so there is no spot for lowercase e. i'm not reading something correctly here. how do i read it? i have a lowercase d,b,e i need to find out.
