I'm pretty sure that Qubes and Q*bert share the same PCB...
Does yours look like this?
I just love the huge foil-backed piece of cardboard shield. Nothing like slow-roasting to help the hottest components on the pcbs, especially the power supply board, run hotter and eventually self-destruct. You can see all of the discoloration of the power supply pcb from component heat in the picture. If you feel that you need this shielding, I'd consider replacing it with a metal perforated cover for better cooling.
Bill
Cover? What cover? You mean the wood and metal "behind" the PCB? Should I remove these?
When I bought the machine it had a original silver cardboard "shield" over the PCB's.
The cover does nothing but hold heat in, throw it in the trash.
I did that... However, Mr. Bill is referring to the silver shield behind the PCB's. I actually am agreeing with him that it really shouldn't be there. What is interesting is that Frenzy (and Bezerk) also have metal behind them. What gives?
