rockinganker
Hello,
I bought a power supply rebuild kit from Riptor and installed it. I now have a working supply that puts out a nice +5 volts. My problem now is, once I hook-up the connectors to the output, the voltage drops to 4.1 volts. I'm not sure what would cause this...any help?
I have checked the sound board to make sure everything is working and I do get the "Hello, I'm On" sound on start-up if the main pcb is not connected. Once I connect the pcb all I get is static. I'm guessing that's from the main board not booting, I could be wrong though.
The two resistors located at R13 and R14 get very hot but still everything checks out, could I have mounted them backwards?
Any help would be awesome.
