Qbert multigame menu
DayOff
Detroit, Michigan
I posted this a while back but didn't really get a concise answer...anyone have a second to check their new qbert multigame for me?
When you are at the game selection menu and move the joystick in a particular direction and hold it there, does the game change once, and then when you release the joystick, does it change again? Meaning, moving the joystick the bottom left once and letting it return to center changes between two games...
I haven't had an issue with gameplay before but thought this was sort of odd..my joystick microswitch connections look original and are soldered in place to the only two tabs that are on the microswitches...
Thanks,
Pete
I think you have to click the joystick in a direction and it changes the game on the menu. Going back to center should not change the game.
At least that's what I have seen on mine. It's gotta be your joystick.
In the unlikely event it's not, one thing you could try if you think your joystick is not the problem is reinstalling the multi game. Perhaps something is not seated properly.
